1010 motor
Charles Jackson
11-26-1999 18:57:26
Is there a combine motor that is the same as a 1010 tractor? I have found a 1010 with cracked block.
Mike Aylward
11-26-1999 19:09:21
 Re: 1010 motor in reply to Charles Jackson, 11-26-1999 18:57:26
Charles, if yours is a gas motor, then a 40 combine engine will work. Both are 115 cubic inch engines. The 600 Hi-Cycles also use this engine. Hope this helps. Mike
