JD 4010 Turbo
4010 Pride
04-19-2006 16:30:51
Will a 4320 Turbo setup fit a JD 4010???
4010 Pride
04-19-2006 19:17:02
 Re: JD 4010 Turbo in reply to 4010 Pride, 04-19-2006 16:30:51
BINGO! Thanks sooo much for the info! I already have the 4320 Ex. manifold and turbo but I still need to purchase the intake manifold, oil supply lines and fittings and an oil return line. I would love to see pics of your configuration, it looks like the hood clearance is going to be extremely tight with mine. I measured from the center of the bottom bolt of exhaust port #2 to the inside of the hood and it is going to be tight. I have a schwitzer 3LM replacement but took the measurements from a bad AiResearch T04 that was bolted to my ex. manifold I will be using. Hoping the height of the Schwitzer is less to allow for more clearance so maybe I can get away without a patch. Also, I have M&W piping to link the impeller side of an original "M&W" turbo to the air cleaner intake stack. Will this same pipe work on a 4320 kit? Also, it looks like the exhaust elbow will exit closer to the radiator, maybe have to avlong the exhaust cut out?? Anyway, I am going to attempt the project soon, I just wanna finish what I start and make sure I have ALL the parts. Thanks a million, please send me pics when you have a moment. Email is j_anctil@msn.com Thanks a million, Jon
4010
04-21-2006 05:26:03
 Re: JD 4010 Turbo in reply to 4010 Pride, 04-19-2006 19:17:02
Are you building a puller? I just put a M&W setup on my 4010. And was wondering the same thing. I would eventually like to go to the 4320 or 4430 manifolds so I can handle a bigger turbo.
4010 Pride
04-21-2006 07:12:32
 Re: JD 4010 Turbo in reply to 4010, 04-21-2006 05:26:03
Hi there, well, the plan is to have something to do a little of both with. Pull in some slightly altered farm classes and still be able to plow or wheel harrow or do whatever with it. I am going to attemt to try the 4320 kit soon when I purchase my used intake manifold. I will let you know if it works or not. From the measurements I have taken so far, the exhaust elbow is going to exit a bit closer to the radiator which means I may have to cut a bit more material out of the hood. The hood clearance may be an issue, not real sure since I took measurments from an AiReasearch T04 and my replacement turbo is a Schwitzer 3LM which I havent seen in person yet, only on Ebay where I brought if from. I would love to go with an M&W kit, but its seems to be too hard to find a reasonably priced used one. So, I will attemp the 4320 kit, she should run pretty good after that. I don"t plan to tinker with the fuel delivery, just force air for now. Should give me 15 horse or so. I just had the upgraded 4020 kit put in the engine, including a new crank shaft. Anyway, I"ll keep you posted!
superfarmer
04-19-2006 18:33:25
As far as I know, it should. you need the ehaust and intake manifolds, and I think you can just turn the water manifold around for clearance. If I were doing it, I'd use 4630 parts so you can put the good intercooler on too. That'd turn heads!! I checked my 4020 and they should fit, so 4010 should be the same. I've got a 4230 done up with turbo and cooler if you want to see pics. Essentially the same engine on the top side. Good Luck!
