Ford guy with JD-M questions
Jim.UT
04-25-2006 15:09:53
I just ran across a barn with two M's that are available. The serial numbers are 20986 and 20990. One of them is in pieces and is said to have a cracked block. The other is missing the carb, but the seller thinks it's on a shelf somewhere. Neither have run in a long time. The complete M was bought new by a man who only had a couple of acres to work so the tractor never got much use (seller's claim). I'm including a couple of photos. What would be a fair offer?
third party image
third party image
third party image
And here's the one that's been partially taken apart.
third party image
Mike M
04-26-2006 05:53:04
 Re: Ford guy with JD-M questions in reply to Jim.UT, 04-25-2006 15:09:53
That one looks like it could be one of the few unmolested originals ? Try to get them as cheap as possible as you are buying a pig in a poke.
Jim.UT
04-26-2006 08:00:03
 Re: Ford guy with JD-M questions in reply to Mike M, 04-26-2006 05:53:04
The claim is that those are original tires. They are severly weather cracked and the tread pattern is the old style so I guess it could be.
Mike M
04-26-2006 08:15:20
 Re: Ford guy with JD-M questions in reply to Jim.UT, 04-26-2006 08:00:03
I would agree that they are.
chris meredith
04-25-2006 18:48:53
i sure would like to buy some parts from the one took apart if you ge them and wan to sell some parts thanks chris
Jim.UT
04-26-2006 14:04:21
 Re: Ford guy with JD-M questions in reply to chris meredith, 04-25-2006 18:48:53
If you need M parts, you probably should look at the link.
ralph oregon
04-25-2006 19:53:52
what parts do you need?? i'm parting out one in oregon. ralph
chris meredith
04-26-2006 04:26:04
 Re: Ford guy with JD-M questions in reply to ralph oregon, 04-25-2006 19:53:52
i need back of seat and trhottel lever for sure maybe some more parts thanks
adamhpopper
04-25-2006 16:14:18
nice looking machine I dont know what your budget is but I would give 1500 to2000 for both the tractors maybe more if there are atachments. good luck.
