 I agree that the old rivets did appear to have been hot set with a much stronger tools certainly than what I can come up with. I don't currently have a 500 ton Verson or Minster OBI in my shop Frank ; ). I thought about putting replacements in hot, but it seemed too difficult to heat the rivet, and then try to assemble with washers on both sides, and then get proper support to set the rivet before it had completely cooled. Perhaps I could have heated them some just on one end before setting them. Both the old and the new John Deere washers appear to be made by a punch press operation. That is to say, they aren't exactly "precise" pieces of hardware. The inside and outside edges on those washers all have tapers and they are a loose fit in the counterbored hole and on a new rivet. There wasn't any appreciable wear on the old washers, and the new replacements were identical in every way except color. Using either seemed to be doomed to the same type of failure because of not having close tolerance fit on the outside diameter. Or to put it another way, with the washers being too small diameter to fit tight in the counterbore hole they go into, I didn't think that I could get a durable repair, no matter what method I used to secure them. Why did this design fail in the first place is what I am after. My approach and thinking on this was that the failure occured because the old washers were too small on the outside diameter, which allowed over time for the ring gear to begin slipping back and forth, I estimated about thirty thousanths, maybe a little more. Thirty thousanths on the ring gear turns into a an inch or two with a clunk noise at the back wheels. By making washers that eliminate any potential ring gear movement in the first place, I am of course hoping to have a durable solution. In order for it to fail, the six washers, or the six ring gear/hub counterbore holes are going to have to suffer damage. It seems to me only then would the rivet start to carry some shear load. So I am not to worried about the way those rivets were set. Having said all of the above, I admit that I am not an engineer and I could be all wrong in my approach. I put this on here to hopefully get a few other opinions and learn from other's experience. I do appreciate others taking from their time to offer comment.
