2010 loader
John J. Otto
05-10-2006 10:07:17
My JD mechanic tells me my 2010 hydrulic pump is up to snuf but just not strong enough for the 36 loader to pickup round bales that weigh about 900 lbs thinking about adding a pump to the pto and using it on the loader on I'v got a pump that flows 18 gal with 2000 psi @ 1800 rpm is this doable
cjs
05-12-2006 17:23:40
 Re: 2010 loader in reply to John J. Otto, 05-10-2006 10:07:17
I've got a 35 loader on my 2010.No problems with it yet (5 years)except had to change hyd oil and clean screen a couple times.Few months ago picked up 360ci engine with auto trans attached,it lifted that and front of pickup it was in off the ground no problem but I was lifting behind the bucket.cjs
cjs
05-12-2006 17:23:22
john j. otto
05-10-2006 12:07:50
thanks for your concern care to help me buy a bigger tractor thanks john
john j. otto
05-10-2006 12:03:58
have one i need more lift out of my loader to unload and stack the bales
steve from mo - dangit!
05-10-2006 11:37:39
 How's about a 3-point hitch spear? in reply to John J. Otto, 05-10-2006 10:07:17
I don't want to be unkind here, but that would be safer in sooooo many ways. If you want to stack big bales, you should probably have a bigger tractor.
