Tuning a 520 Carburetor
'52 Farmall H
05-22-2006 20:31:34
I just disassembled and cleaned the carburetor off my friends 520. It"s all back together now and I"m going to put it back on the tractor Tuesday evening. I"ve searched for info on how to adjust/tune it, but couldn"t find what I was looking for. Would someone be able to share this procedure with me? Thanks!
buickanddeere
05-23-2006 08:01:21
 Re: Tuning a 520 Carburetor in reply to '52 Farmall H, 05-22-2006 20:31:34
You adjust each idle screw while running on one cylinder. This step also locates carbs with plugged idle circuits.(lots) The mixture should be as lean as possible without stalling or stumbling when the throttle is cracked open. 1/2 to 1-1/4 turn depending..... ..... The main just bias screw maybe anywhere from 0 to 5 turns. Depends on the tractor,fuel and elevation. I set ours when running 100% on the pto generator. Too lean will make the exhaust pipe glow red out past the manifold. 1-800-522-7448 and get the manuals. You won't wasting $$$ and you will doing you and your buddy a favour.
'52 Farmall H
05-23-2006 08:32:28
 Re: Tuning a 520 Carburetor in reply to buickanddeere, 05-23-2006 08:01:21
So you are saying I should disable one cylinder while tuning the other? I was wondering if that would be the case since there are two carb throats.
Just pull the plug lead off?
Thanks.
johns48b
05-23-2006 05:01:12
look at JDHPubs.com. i'd start out with each adjusting screw back out 1 turn. give it plenty of time in between turns on the screws when you start backing them out. it doesn't take much to open them to much and foul a plug.
'52 Farmall H
05-23-2006 08:37:26
 Re: Tuning a 520 Carburetor in reply to johns48b, 05-23-2006 05:01:12
Wow! Great website! Thanks for the link! I'll definitely be reading this soon as I have a 1939 H myself.
