Loader - Thank you
Joe-SE Az Ranch
05-23-2006 06:29:29
We bought a 4020 with 148 loader hooked up to the SCV's, and you had to use the remote level while using the loader controls. I moved the valve and the controls and hooked up the hydraulic lines for live pressure. All the information for how to do that was right here and I didn't have to ask one question. I wanted to thank all of you who contributed, and particularly "Pete/ME", "Mike M", and "Gerald J." from Jan 2005 and June of 05. We ranch in S/E Arizona and grow our own hay, and ripping apart the tractor and doing this project was great for my son (13). He basically did the project himself with a little oversight. So again, my thanks to all of you whose conversations I eavesdropped on in order to get the info we needed to make this happen. Hopefully one day I can repay the favor. Best Regards, Joe.
Corky
05-23-2006 13:11:02
 Re: Loader - Thank you in reply to Joe-SE Az Rancher, 05-23-2006 06:29:29
I have a JD 4010 with loader, but I don"t know if the hydraulics are connected most efficiently. Where in the archives did you find your information?
Joe-S/E Az Rancher
05-23-2006 14:36:39
 Re: Loader - Thank you in reply to Corky, 05-23-2006 13:11:02
There's a couple great discussions (including restrictor valves etc) look under (I think) joystick loader 4020. If you look for a discussion in January of 2005 and June of 05 should have all the info you would need. Good luck. Joe
Mike M
05-23-2006 06:38:04
Glad to here you got it done. It sounds like you had alot better luck with the archives than I seem to . LOL
I can't imagine a loader on a tractor having to run it through the SCV's that has to be way slow.
