JD 720 Camshaft Intersting wear pattern
Tyler-MO
06-07-2006 12:01:31
third party image
I'm just posting the interesting wear spot on the cam of my late model 720 Diesel. It's the anti-reverse cam. The close up is of the injection cam lobe for #2 cylindner.
I have a decent cam out of a 70 diesel. Anyone have any clue if it would work properly in my 720?
Tyler in MO
JDknut
06-08-2006 03:45:53
 Re: JD 720 Camshaft Intersting wear pattern in reply to Tyler-MO, 06-07-2006 12:01:31
Nice site and pix, Tyl. Where in MO are you?
Tyler-MO
06-08-2006 06:27:55
 Re: JD 720 Camshaft Intersting wear pattern in reply to JDknut, 06-08-2006 03:45:53
I'm in the SE corner about 90 miles south of St. Louis.
Thanks,
Tyler
Rousseau
06-07-2006 16:26:36
Hello Tyler
Your 70 cam will work and yes it can run backwards. It will only do so if you lug it down close to its last breath.If you are goin to pull it you need the anti reverse.My 720 had the same ware pattern.Some one tried to weld it.These tractors are lot fun and work.Do it right!
Have fun Russ
buickanddeere
06-07-2006 21:03:14
 Re: JD 720 Camshaft Intersting wear pattern in reply to Rousseau, 06-07-2006 16:26:36
Albert warned us about cam wear on the injection lobes in NY 2005. Many tractors need the cam/injection followers aligned to run the cam centered on the lobe. Installing a used cam is just purchasing somebody elses worn out cam/followers. Both need to be resurfaced at Robert's Carburator.
buickanddeere
06-07-2006 15:16:23
Your 720 will now have the ability to run backwards.
