1937 A Carb Mag
1937 A
06-18-2006 05:49:34
Can anyone tell me what model carb and mag a '37 A should have? Also would like to know if there are any sources out there for them.
Thanks
jc37A
06-18-2006 18:10:56
 Re: 1937 A Carb Mag in reply to 1937 A, 06-18-2006 05:49:34
My 1937 A ser.#450432 has a dtlx-18 carb and wico X mag. Hope this helps and good luck!
1937 A
06-18-2006 18:42:09
 Re: 1937 A Carb Mag in reply to jc37A, 06-18-2006 18:10:56
Thank you! The next battle is to find them. :-)
P Browning
06-18-2006 06:10:21
1937A -- a visit to Roberts Carb Repair site (below) should prove to be a great start. When you get there, scroll down to Technical Information and there you will find data on both magnetos and carbs used on various two-cylinder tractors. ALso, give Robert a call on sourcing. Enjoy (PatB).
P Browning
06-18-2006 06:12:18
 Re: 1937 A Carb Mag in reply to P Browning, 06-18-2006 06:10:21
2nd Try!
1937 A
06-18-2006 08:39:11
 Re: 1937 A Carb Mag in reply to P Browning, 06-18-2006 06:12:18
Thank you Pat! Trying to complete a tractor that my mothers father or grandfather purchased used, was the main source of power still around the 50's-60's I was told. Some parts were robbed off of it in the years, and it's in sad shape. Needs a hood, exhaust, carb, and mag for sure. For several years the engine was kept unstuck as well, but when the man left the farm and started renting it out, it never got any attention. Would you happen to know of a source for a hood?
Thanks
JD @ Antique Acres
06-18-2006 11:03:49
 Re: 1937 A Carb Mag in reply to 1937 A, 06-18-2006 08:39:11
Dave Geyer in IA 319-628-4257 or Detwiler Tractor Parts in WI 715-659-4252. Both are good quality
1937 A
06-18-2006 11:12:43
 Re: 1937 A Carb Mag in reply to JD @ Antique Acres, 06-18-2006 11:03:49
Thank you!
