Cutting rubber
Johan
10-28-2003 08:46:45
What is the best way of cutting rubber for steel wheels?
Eric S
10-31-2003 18:23:10
 Re: Cutting rubber in reply to Johan, 10-28-2003 08:46:45
We just bought a house that had a tractor tire as a sandbox in the yard. We wanted to do something different, so I cut it with a reciprocating saw. Worked alright, but took quite a while. I didn't use any lube or water or anything.
When I was a kid, I remember watching my grandfather cut one for steel wheels using a chainsaw. Didn't give a clean cut, but neither did my method. His made quite a mess, so be ready to clean. Went fast, though.
Glen in TX
10-29-2003 12:36:29
I have used a circular saw, jig saw, but like using my reciprocating saw best. Use the best metal cutting blades and then you can cut right through the cords too. Cut up a wide 30.5-32 tire a few years ago to make a dog house out it in a hour or less. Works best if you can cut from the inside along a chalk line.
JP
10-29-2003 05:32:40
I have used a table saw(not on large tires of curse) and a hand held circular saw. Both work well even on the steel belts but will definitely dull the blade. Frank mentioned use a large kerf; he was on the right track, but it is more important to use a blade with a wide "set" and not just kerf. A wide set is teeth bent outwards from the blade. A wide kerf is simply a wide blade overall. A wide set allows the rubber to close in around the blade behind the cut and not bind as much.
F-I-T
10-29-2003 09:25:14
 Re: Re: Cutting rubber in reply to JP, 10-29-2003 05:32:40
JP:
You caught me. Too many years away from woodworking. The set will allow the rubber when it springs back to not rub on and trap the blade.
Frank
John T
10-28-2003 10:45:50
I once observed a guy use a Sawz All (the generic term I think Milwaukee and Dewalt etc make them) to cut a tire apart and he kept water on it if I recall?? John T
Woody (NE)
10-28-2003 10:10:24
I just talked to a rancher who did some cutting on an 8' tire he will use for a cattle water tank. He said he used a sharp butcher knife and got some tire lube from a tire store. Said the rubber really cut quite easily. He then used a cutoff saw to cut the steel belts and that was not so easy. Good luck.
F-I-T
10-28-2003 09:24:03
Johan:
I have used a reciprocating saw and it worked well. Use a large kerf blade. Then I used a belt sander to dress the edge. An 80 grit belt does a fair job.
Frank
Clooney
10-28-2003 09:08:03
Johan, if it's hard rubber a band saw works good. I use glass cleaner as a rubber lube while cutting. ~If it's soft rubber a band saw will still work but tends to pull the rubber down even with a lubricant.
~Be real careful cutting soft rubber as that rubber can catch & pull your fingers into the blade.
