hydraulics
jksom
07-06-2006 07:32:45
What is the difference and advantages of closed center hydraulics verses open center hydraulics? Example,70s JD 820 vs JD 1020
msb
07-06-2006 18:15:00
 Re: hydraulics in reply to jksom, 07-06-2006 07:32:45
A closed center system will operate more than one function at the same time much,much better than even the best open center system.
Bob
07-06-2006 07:39:34
Closed-center systems do not pump (much) oil when hydraulic functions are not being used, saving power, and reducing heating of the system's oil.
It is easier to "tap" an extra valve and hydraulic circuit into a closed-center circuit, as you simply "tee" into the pressure line, and return circuit, rather than having to worry about open-center valves in series, and "power beyond" functions, etc..
