another wheel question for Duane
34gpa
07-09-2006 07:22:30
I have a set of 16 in front rounds with the no hc258. Any idea what they fit? There are no bearings or caps so no help there. Your help is very much appreciated. Thanks
Maark
07-09-2006 17:42:00
 Re: another wheel question for Duane in reply to 34gpa, 07-09-2006 07:22:30
Do those wheels use a big hub cap that uses 4 bolt or just 3 bolts?
34gpa
07-10-2006 06:59:15
 Re: another wheel question for Duane in reply to Maark, 07-09-2006 17:42:00
They use a big cap with 3 bolts. I noticed there is a bearing in one, but to get it out you have to grind off 3 rivits holding the retaining ring on. Im going to see if I can find a no. and take pictures and send them to Duane Larson. Do you have any ideas? Also the spokes are 9/16 inch.
Duane Larson
07-09-2006 07:37:38
34gpa,
They are not in my database (at least yet, I have some notes from recent shows to go through but I don't recall the number). Would it be possible to email me (jdlarson@comcast.net) a pix of the wheel, hub, and number? Bearing numbers have helped narrow down applications in the past but sounds like that won't work here.
