Loss of hydraulics on 2440
Jerry Marks
07-13-2006 14:06:36
Help!!! JD 2440 with front loader lost all hydraulics....three point hitch, power steering, front loader controls. Fluid levels are right on the money. Any suggestions on how to diagnose the problem or is this a common malady for this model JD? Have no manual for this tractor. Thanks in advance for any help.
Jerry
K.B.-826
07-13-2006 16:53:40
 Re: Loss of hydraulics on 2440 in reply to Jerry Marks, 07-13-2006 14:06:36
Check out the coupler between the front crankshaft pulley and the main hyd. pump. Those couplers will fail once in a while. You'll probably need to remove the coupler to do a good inspection of the splines that spline onto the pump shaft. Not hard to do, and you can replace your fan belt while it's off.
Jerry Marks
07-13-2006 19:43:40
 Re: Loss of hydraulics on 2440 in reply to K.B.-826, 07-13-2006 16:53:40
Just in case that isn't the problem, where would I look next? The sheared spline sounds about as logical as it goes, but you know old tractors. They have a way of being obstinate. Thanks for the suggestion. I'll be elbow deep in green and yellow tomorrow. Thanks again!
Jerry
K.B.-826
07-13-2006 20:19:58
 Re: Loss of hydraulics on 2440 in reply to Jerry Marks, 07-13-2006 19:43:40
Has the filter been changed recently? I'm a little unfamiliar with Deere's utility tractors like the 2440. If it was a Waterloo-built tractor (4020, 4430, ect.), the next places I'd look would be the suction screen, transmission pump, and the transmission pump driveshaft on the newer tractors. I'm pretty sure the utility tractors have some sort of suction screen, and they must have a transmission pump to supply the main pump, as the piston-type main pump cannot draw oil. Failing that, I'd suspect the main pump's stroke control valve, or a major internal leak.
Jerry Marks
07-13-2006 22:50:26
 Re: Loss of hydraulics on 2440 in reply to K.B.-826, 07-13-2006 20:19:58
I really appreciate the feedback. When you refer to a transmission pump, can I assume that one has to service this pump thru an access plate or is complete removal of the transmission necessary. Sorry for asking all of these questions, but I'm just trying to minimize the job and avoid a complete teardown, if possible. Thanks again for all of your assistance. I'll let you know how I make out.
Jerry
buickanddeere
07-14-2006 03:08:07
 Re: Loss of hydraulics on 2440 in reply to Jerry Marks, 07-13-2006 22:50:26
You will cost yourself extra time and money flying blind without some info. Mother Deere has a parts lookup section on her web site. 1-800-522-7448 for the service manual or wish you had.
Rich in NY
07-14-2006 02:51:30
You'll have to split the tractor between the clutch housing and transmission to do the transmission pump. About 7 steel hyd lines with O-rings on each end too.Been there, done that. Better get a service manual if you go there.
Jerry Marks
07-14-2006 06:14:10
 Re: Loss of hydraulics on 2440 in reply to Rich in NY, 07-14-2006 02:51:30
I really appreciate all of your responses and all of the suggestions. I'll get the manual. Let's hope that its the connector between the main pump and the crank pulley. If not, I suppose I'll get a lesson in green and yellow innards. Thanks again!
Jerry
