A with 60 head and carb sold ebay
1936
07-28-2006 18:40:51
A 60 head and carb on a styled A sold for about 1100. What about this cross over? Anyone tried this and what were the results?
Glen in TX
07-29-2006 08:50:12
 Re: A with 60 head and carb sold ebay in reply to 1936, 07-28-2006 18:40:51
Early 60 gas & all fuel still had the same single induction carb and head as the late A. Later 60 went to a dual induction carb, manifold and head setup for smoother running, more fuel economy and more power. As said below many late A and 60 parts will interchange. The factory LP 60 was always the dual induction setup.
nahRalphinWI
07-29-2006 10:09:41
 Re: A with 60 head and carb sold ebay in reply to Glen in TX, 07-29-2006 08:50:12
I knew the AF's had the single barreled throat, but I thought all of the gassers came with a dual carburator. I remember looking at what was the first(?) 60 at a local dealer and marveling at the dual carburator. It struck me because we had a '38 Ford pick-up which had a two barrel. It seemed like the 60 made it from idle to full speed in the time that it took to move the throttle to full open,
Mike Aylward
07-29-2006 09:17:12
Glen, as you probably know (but some others may not) the original carburetor on the 60 LP tractors was a SINGLE barrel, but "Y-ed" back to the dual induction head. These carburetors were all subject to a factory recall and were replaced by the familiar dual induction LP carburetor. I bought a 60 LP from it's original owner and he said the tractor actually ran better with the single barrel carburetor than it did afterwards with the "improved" version. This is only a reported opinion of someone else. But yes, from the block forward most 60 parts can be installed on a late A tractor (648,000 and up). Mike
CLW
07-28-2006 20:34:02
Yes it works. There are a number of things that will interchange between the A and 60.
Bob Bedlan
07-28-2006 19:01:49
I don't know, but I have a 60 propane head if
anyone needs one.
Drew
07-28-2006 20:25:30
 Re: A with 60 head and carb sold ebay in reply to Bob Bedlan, 07-28-2006 19:01:49
Do you have the manifolds off that head? I am interested in a 60 LP manifold set.
Kevin
07-28-2006 19:14:58
What are you looking to get for it?
