JD GP Spark plugs
40 JD G
08-01-2006 06:04:30
I a working on a GP and have a very hard time finding the original tapered pipe thread spark plugs, i order two different ones at deere that were in my parts book and they were not right, and i tried car quest and he said they are discontinued. Any help would be great. Thanks
Nick
Duane Larson
08-01-2006 08:23:29
 Re: JD GP Spark plugs in reply to 40 JD G, 08-01-2006 06:04:30
40 JD G
The cheapest 1/2" pipe thread plug around is the Autolite 3095. Champion also sells the 25 (now 525, I think) which is a 1/2" pipe thread plug but is more expensive.
It depends on how original you want to go. Your tractor probably came with Champion 7 plugs - very hard to find. They were replaced in September 1929 by the Champion 31 and they are around but not "cheap". However, they are a two-piece take-apart plug which is easy to clean well, so it is likely the last plug you would buy.
Marty Z
08-01-2006 07:47:57
Yup it was a model T spark plug and I ordered a whole box from NAPA auto parts
Duane Larson
08-01-2006 08:27:23
 Re: JD GP Spark plugs in reply to Marty Z, 08-01-2006 07:47:57
Marty,
Model T's used the Champion X plug, which are being remade by Champion occasionally. However, that is not the plug Deere recommended for the GP. The electrode structure and insulator is quite different from the Champion 31. But they will fit and unless the GP is worked I don't know that one can tell any difference.
Earl-IL
08-01-2006 07:38:52
40 JD G, I think the plug you are looking for is a 3095 Autolite, They are available from The Brillman Co. 888-274-5562. or www.brillman.com. Earl
Mike M
08-01-2006 07:06:39
I was able to order a box from an autolite dist. I'd have to check the part number. I have seen them advertised in engine magazines but they want alot for them. Ask your local parts house for model T ford plugs I think they are the same and they should have a listing on them.
PENSFAN
08-01-2006 07:39:35
 Re: JD GP Spark plugs in reply to Mike M, 08-01-2006 07:06:39
I believe the number I use in my GP is an Autolite 3095, tractor is 30 miles away and my memory has let me down before so you might want to double check that number.
