We had a '48 "A", and I have owned several others over the years, most of which I overhauled through block and head removal, and on those pressed steel frame models, the head will actually come out the bottom if you lift and twist ans turn it correctly. BE READY FOR IT FALL FREE! The manifold can stay in place. Just remove the carbnuretor and exhaust pipe. Removing the fanshaft is a must for block removal, but you do not have to remove the governor, and unless you have a reason to, I would not. Just loosen the radiator a bit and slide it forward, and that will gain you enough space to slide the fanshaft forward to clear the bevel gear on its end. If you need to remove the governor later then you can remarry those two units and set the gear heel and lash (IMPORTANT!). There is quite a bit written on this in the searchable archives here. On the block, there is an oil pipe that is hooked to it that I seem to remember you will need to remove before it can move forward. That might not be the case, but you'll be in there taking off the rod caps so you can check then. The block will slide forward a bit and it will lift out the top. You might need an engine hoist as it is probably more than you want to lift, though we used manpower alone several times. A hoist is really handy in case you have to leave the pistons and connecting rods in the block as you may on one that is stuck. You have a much better chance of saving parts of you can operate on the stuck pistons with the block out of the frame. Frank
