John Deere M 61HB combine engine
300winchester
08-02-2006 09:16:59
Does anyone know where I can find engine kit or parts for this engine
Thanks in advance
Glen in TX
08-02-2006 09:34:30
 Re: John Deere M 61HB combine engine in reply to 300winchester, 08-02-2006 09:16:59
Have you tried JD dealer ? It's a 303 cubic inch, 6 cylinder gasoline right? Same also as HA-303-G or 303G5H. The SM2080 service manual covers 132,152,180, 202, & 303 power units.
The numbers following M61HB are the serial number and dealer may need that also.
M= motor
6= 6 cylinder
1= gasoline engine
H= Harvester works
B= First variation (A= initial design and C= 2nd variation)
300winchester
08-02-2006 09:41:17
 Re: John Deere M 61HB combine engine in reply to Glen in TX, 08-02-2006 09:34:30
Glen
How much would you pay for a stuck motor that appears to be in good shape
Thanks
Mike
Glen in TX
08-02-2006 18:10:06
 Re: John Deere M 61HB combine engine in reply to 300winchester, 08-02-2006 09:41:17
The 303 was used in 55 & 95 combines and 699 cotton picker in gas, diesel & LP versions. Also used in gas version in 6600 combine. Anything besides the later 404 diesel in a 6600 was a real doggy engine in it anyway. We had a later 6600 with the 404D and much better power and machine than early ones.
Glen in TX
08-02-2006 12:50:53
Not much unless you just really need it for parts for another combine engine. That's all they were used on I think? Depends on how stuck or why it is stuck? Stuck rings from setting or did it happen because something else went wrong in engine?
