5300 Will Not Start
01z71
08-13-2006 18:36:24
I changed the fuel filter (Final Water Seperator) and re-opened the fuel line valve & bled the air out of the system. The tractor ran for about a minute and a half and then died.
I changed the filter because recently it has been surging and stalling occasionally.
The tractor will not start now. I have tried repeating the bleeding process to get any air out of the system and still no luck. Any Ideas?
01z71
08-14-2006 20:56:24
 Re: 5300 Will Not Start in reply to 01z71, 08-13-2006 18:36:24
I tried re-bleeding the system. Still Nothing. Good Call on the vent hose I pulled off the slow triangle emblem and the hose had dry rotted and fallen off and the plastic piece was filled with gunk.
However, I had a mechanic look at it and he said it was the injection pump. I called the Deere place and they wanted $2,100.00 for a new one or it will take two weeks to rebuild my current one for $400 to $600.00.
Oh well, with the exception of one starter a few years back this has been a very reliable tractor. It has 2840 hours on the clock.
Thanks for your help and I will keep you updated as this progresses. Thanks Again!!!
WV2cyl
08-14-2006 10:29:16
I have a 5400 that was giving me fits of surging and stalling and finally quit. I tried to bleed lines and anything else on it and found that I was not getting fuel. The mud dobbers had stopped the vent line behind the slow moving emblem and the tractor was starving for fuel as it would create a vacuum in the fuel tank. After a lot of heartache I called the service mgr. of our local Deere dealer and told him what I had found. He said maybe that is the answer to several others that we are having problems with.
bighead
08-13-2006 20:03:05
Bleed it again until no air comes out of that bleed screw. Loosen all the injector lines a little (maybe 1/2 turn) at the injector. Keep cranking it until fuel comes out every injector line- til it runs down (only crank maybe 15 seconds at a time... if the starter gets hot to the touch, let it cool down). Tighten the lines, start it up.
