440 jd
jj place
08-17-2006 17:21:30
hey just got a 1960 something yellow jd tractor we got to start after few can wd 40 and start fuild it ran i could walk faster then run it sound bad like bad lifter or valve problem now before spent a lot of green back just want to know a little about 440 yellow john deere industrials type it two cylinder has back hoe and loader if the motor not repair i was going put one of other tractor like my 8n ford i know why ruin ford but look at it has slot where gear shift then up by the clucth there a lever and i don't know if it hi or low split shift and has other lever on it and other person don't know all about ether
Mike M
08-18-2006 06:12:04
 Re: 440 jd in reply to jj place , 08-17-2006 17:21:30
A slot in the gear shift ? The tower has extra slots in the side for a spring to hold it in neutral ? Maybe this is what you ask ?
The lever up above the clutch could be an optional directional reverser. You push the clutch in then pull the lever back and let the clutch out and you are going backwards at the same speed as whatever forward gear you were in. It may also be a good idea to not use this too much as not to tear it up as it is pretty old and just shift into reverse gear.
jjplace
08-17-2006 19:31:41
it gasoline power 12 volt system i was not lucy to find diesl model
buickanddeere
08-18-2006 08:40:23
 Re: 440 jd in reply to jjplace, 08-17-2006 19:31:41
Being 12V who knows how the electrical system may have been cobbeled up. They were 6V positive ground with a generator from the factory. There maybe a 1/2 burned out 6V coil in there without a ballast resisitor. Backwards coil polarity is a very common find. If there is dirt, gum, goo or rust anywhere in the fuel system. She will never run decent. Many times the tinkerer working without a manual. They adjust the carb and crank the mixture full rich when tring to lean the mixture. If equiped with resitor core wires it will never run right.
buickanddeere
08-17-2006 18:26:40
Gas, diesel, wheels, crawler? If returned to factory specs, a 440 will eat a Ford 8N alive. As previously stated the Deere's backhoe will snap the Ford's main castings. Have you received any service manuals with it or have you ordered them yet? 1-800-522-7448 cheap from Deere. All some 2-53 Detroits need is a fresh set of N35 injectors. The gassers usually need solid core plug wires, the coil polarity corrected, Auto lite 216 plugs and a new distributer bushing. Either will require adjusting the valves/valves + injectors, clean fuel and a clean airfilter.
Big City
12-20-2006 21:11:35
 Re: 440 jd in reply to buickanddeere, 08-17-2006 18:26:40
My friend is looking at a gas 440 crawler with a 6 way blade. the owner is asking 6500 dollars. the tractor seems straight and the under carraige is good. is this a decent price? is the two cly. motor underpowered? Thanks Big City
CPeter
08-17-2006 18:02:27
First, this is a lot more tractor than an 8N ford. It may need some minor work like a tune up and adjust the valves, but don't write it off yet. I doubt your 8N Ford could handle the backhoe weight. If you decide to sell, where are you located? a lot of people would be interested.
CPeter
