2010 JD cowl
Jerry Clasen
08-28-2006 18:09:17
On the early 2010 tractor, some had inspection holes on the sides of the cowl- are there covers for these holes or are they open?
HTR
08-28-2006 19:27:54
 Re: 2010 JD cowl in reply to Jerry Clasen, 08-28-2006 18:09:17
Cover #4 in Bobs picture covers the holes In the early cowl. Panel #25 was not removable on the early 2010s. This made the remote pipes and valves hard to remove, as you had to work through back cover hole #28. The later tractors had the right side panel removable, but the holes in the cowl, that made it easier to work on the shift quadrant, were eliminated.
Bob
08-28-2006 19:55:33
 Re: 2010 JD cowl in reply to HTR, 08-28-2006 19:27:54
I have one in the shop right now that has a farmer-built cover to provide access on an older one, made without cover #25.
It's kind of unique!
Bob
08-28-2006 18:23:33
Which of these pieces are you saying have the holes in them?
Third Party Image
Bob
08-28-2006 18:23:19
Third Party Image
Jerry Clasen
08-29-2006 17:03:25
 Re: 2010 JD cowl in reply to Bob, 08-28-2006 18:23:19
I have a cowl that does not have the removable right side panel but has holes in what would be #4 , but it is not removable either. My question is if there are covers for these inspection holes? there are 4 tapered screw holes in tis permanent cover like there would be a cover like #4 to attach. there is no paint marks showing any wear. This is an early 2010 RU LP
