35 unstyled A wheels
Jim/Iowa
09-06-2006 17:00:45
Hello, was wondering if 12 spline cutoffs on a B I found will work on my A. Has 36" cutoffs now that are shot (deep drop center style). Local CO-OP says good luck finding replacement outer rims. Help guys, what are my options??
Leroy
09-07-2006 05:19:54
 Re: 35 unstyled A wheels in reply to Jim/Iowa, 09-06-2006 17:00:45
If you have just the rims bad you should be able to find used 38" rims that you could have welded on, you say the spokes would be too short, just have a short piece of bar stock welded in the same as you probably would also have to do with new 36" rims as in removing the rusted out rims the spokes would get cut too short to put the new rims on. Also should be able to get new 38" rims from these tire places mentioned here all the time. and 38" rims for 11-12.4X38 tires is what a lot of the tractors were converted to, this is what I had on a 38 A and to me the 12X36" do not look rite on them and that the 12X36 is the same height as a 11X38 and if your rims are so bad you are replacing them then I suspect you are also having to replace your tires and you would be able to find the 38" a lot easier than the 36" and also enough cheaper to more than pay the aditional cost to repair your rims with 38 instead of 36"
Earl-IL
09-06-2006 17:16:40
Jim, I think your "A" is 10 spline & diff. diameter. Earl
