3010D PTO clutch
Jim Glidewell
09-17-2006 12:48:25
I recently had the engine on my 3010 rebuilt. Had to take tractor back to have rear main seal replaced because oil was leaking into clutch area. Mechanic replaced seal and washed clutches out with cleaner. I was able to bale about 34 bales with tractor. Tractor sat for about a month before I needed to bale again at which time pto would hold for about half the bale and start slipping. There doesn't appear to be any oil leaking into clutch. Help, Jim
msb
09-17-2006 19:27:09
 Re: 3010D PTO clutch in reply to Jim Glidewell, 09-17-2006 12:48:25
Can you feel any resistence in the PTO lever when you engage the clutch?Sounds like the adjusting bolt locks were not locked down tight.Even with some oil on the clutch there should be enough pressure on the clutch to run a baler unless it is a big baler,round or otherwise.
Jim Glidewell
10-03-2006 18:21:44
 Re: 3010D PTO clutch in reply to msb, 09-17-2006 19:27:09
No, there is little to no resistance when the lever is engaged. Not knowing much about this, can the locks be tightened through the clutch inspection opening? I appreciate your help. Jim
