Tires for 37 A
John Hicks
10-29-2003 07:22:41
I'm putting a set of rear cut-offs on my A to replace the skelleton steel. The old old tires that were on the cut-offs are 11.25- 36's. I think I want to put a set of Titan 11.2-36 on. The rim width is 6". Would this be OK.
Thanks, John
Bman
10-29-2003 17:34:47
 Re: Tires for 37 A in reply to John Hicks, 10-29-2003 07:22:41
I would go with the 11.2 X 36. The 12.4 or larger is too much tire for a 6 inch rim.
Clooney
10-29-2003 09:22:35
John, an 11.2 is a MUCH smaller tire than a 11.25..
~The old 11.25 is now replaced by the 14.9..They measure tires differently now you know..
~The only problem is that a 14.9 is pretty wide for a 6" rim & will look all pinched in on the side walls.
~You might want to look at a 12.4 or 13.6 X 36 on those narrow rims.. ~Call M.E. Miller Tire @ [ph: 419-335-7010] for his recommendation on fitting your narrow rims…
