JD1010 positive ground
Joe Murph
09-29-2006 20:22:54
What is the reason for my JD1010W(backhoe)
having a positive ground, with a 12volt
battery.
If I need too boost battery with my truck
how should the cables be hooked up.
Thank You for your help Joe
jdemaris
09-30-2006 15:23:52
 Re: JD1010 positive ground in reply to Joe Murph, 09-29-2006 20:22:54
The reason for the positive-ground - goes way back to early automotive electrical engineering days. There were two opposed schools of thought about the direction electricity flows - with two competing theories - the Hole Theory, and the Electron Theory. Depending which theory you put your hopes in led to choosing either positive - or negative ground. It was believed, by those of either school-of-thought that choosing the right grounding would provide advantages - such as less corrosion in connections, fram metal, etc. Now - many years later - it has been proven that both ways of grounding have their good and bad and none seems better than the other overall. Thing is - when tranisistors and other semi-conductors became commonly used - a polartity had to be chosen and stuck with - for parts standardization. Negative ground was chosen, and that's how just about all alternators, radios, etc. are designed for.
Bob
09-30-2006 00:10:44
You match the polarity of the cables to the polarity of the BATTERY, at both ends... Red to (+) post, black to (-) post.
DO NOT allow metal parts of the tractor and the boost vehicle to touch, as that will cause a short, since the ground polaritys are opposite.
