ultradogmn@yahoo.com
Jerry MN
10-02-2006 13:59:56
I must have a bad infection or disease.
Went to buy a 290 planter yesterday and came home with the planter and a complete set of cultivators - front and rear for a JD A - and I'm a Ford man...
The guy I bought them from says they were on his hand start A when he bought it. Cultivating with an A is kind of like swatting flies with a sledge hammer isn't it?
Anyway, He says they will fit on either an A or a B so I'm asking you experts here if he is right.
I might have them sold already but the guy has a B and I don't want to misrepresent them.
He's just going to do some scratching the soil for deer plots.
Will they fit on his B?
Many thanks
Jerry
CLW
10-03-2006 14:05:44
 Re: ultradogmn@yahoo.com in reply to Jerry MN, 10-02-2006 13:59:56
Guys he said they were on a hand start A. If they were from that era then they would not be quick-tack and would not have cross brackets. The would be in two sections that are mounted one side at a time, bolting to the frame with the braces bolting to the front of the tractor. In either case they will work on either the A or B.
wikevin
10-03-2006 10:19:53
ET is right they will fit but the front brackets are a little wider, I had one on the 50 from a 60 and it worked fine, also had to flip over the top bracket to line up with the pin hole, some models wont have this problem as top bracket was just a bar had no hole in it. Curious what you paid for it, sold mine on ebay for about 85 it was a stiff shank I wanted a spring tooth style, Now that I dont have one and am looking everyone thinks there made of Gold,I guess Ill keep lookin.
ET
10-03-2006 06:19:24
The cultivator will work but the frame is wider on the A. There are diffrent upper and lower cross brackets for the front of quick atatch frames.
Bill(Wis)
10-02-2006 16:35:31
Yes, they should fit fine. My neighbor bought a JD cultivator for his WWII A (42,3,4?) and his brother used it on his old B and then the neighbor bought a new '49 A and then his brother-in-law bought a '52 B. It fit on all of those tractors. They got away with having just one cultivator. I have to point out that they all had the Quick-Tach set up on all of the tractors and the cultivator. Otherwise the JD cultivator is a real bear to get on and off. They are a good tough cultivator.
CLW
10-02-2006 14:14:06
They should fit the B. Deere made the frames longer around 1938-39 I think it was, so the cultivators and planters could be used on either the A or B.
Woops!!!
10-02-2006 14:01:46
Got my lines mixed up.
Title should have been "Cultivators for a JD A"
