Load Control Shaft Leaking on JD1020
1020gas
10-02-2006 17:58:50
JD 1020 load control shaft is leaking hydraulic fluid at the end of the shaft where the draft link connects to it. This is an early 1020 with nut and cotter pin holding the draft link. can anyone give me some info on repairing.
I have a service manual but it"s showing the later 1020 parts. Is it just an oil seal on the housing that can be replaced?
Tx Jim
10-03-2006 03:42:54
 Re: Load Control Shaft Leaking on JD1020 in reply to 1020gas, 10-02-2006 17:58:50
Drain hyd oil,remove nuts and draft links. Put draft control in "D" and pull shaft out either side. Renew seals,chech shaft for wear,apply hyd oil to shaft and insert. Tx Jim
1020gas
10-03-2006 05:40:26
 Re: Load Control Shaft Leaking on JD1020 in reply to Tx Jim, 10-03-2006 03:42:54
Thanks TxJim, Does that shaft slide right out or does is drive out hard also do the seals need a special tool to get them out or can they be pried out of the same side there on
