John Deere M Rear Tires
John Moore
10-18-2006 18:39:17
Need to replace 13.6-24 rear tires on JD M I'm trying to restore. Can you guys give me some advice about going to a smaller tire using the same rim? The M operators manual reads, "8,9, or 10-24 4 ply tires. Thanks much. John
Dean Glover
10-18-2006 19:41:58
 Re: John Deere M Rear Tires in reply to John Moore, 10-18-2006 18:39:17
Hello John, My M has 9.5X 24 tires on it. This is the size most of them should have. Originally They were 9 but the new designation is 9.5. You should measure the rim width between where the tire bead fits to determine the size tire that should be on the rim. If it measures 8" it should have 9.5 tires, if it measures 9" it should have 11.2 tires ect. Hope this helps, Dean
JDM
10-20-2006 10:08:35
 Re: John Deere M Rear Tires in reply to Dean Glover, 10-18-2006 19:41:58
I have 11-24s on my M. The parts book says there is a rim for 11-26 and 12-26. Do I have rims from something else or is a 11-24 and 26 so close it doesn't matter?
John Moore
10-19-2006 07:33:01
Thanks Dean.
John
