why don't anybody talk about jd industrial 440
jjplace
10-20-2006 06:58:09
I have not heard anybody talking about good old industrial 440 jd i got one with loader and backhoe still working on the motor getting it runing still have problem get part for it they tell me it to old which motor interchange with it will 440 ag tractor work it the cam is problem it flat probe or this there four cylinder will interchange with it or do i have cam it resurface ???
CH
10-21-2006 16:54:30
 Re: why don't anybody talk about jd industrial in reply to jjplace , 10-20-2006 06:58:09
I have motors both gas and diesel, Parts and manuals for that machine Email me for my link
Handsome Jim
10-21-2006 06:56:58
Brandon's Wierd Deere site has info on the Industrials. You can link to it through Rummy's Johnny Popper site.HJ
jdemaris
10-20-2006 11:42:39
Seems parts should not be hard to find. Either a 106 cubic inch 2-53 Detroit Diesel, or a 113 cubic inch Deere gas engine. With the latter, as other's have already mentioned, I think an engine from a 40, 420, or 430 will fit fine. The two cylinder engine - 113 cubic inches, uses the same bolt pattern as the four-cylinder used in 1010 gas engines of 115 cubic inches - but obviously, the four-cylinder 1010 engine will be longer and the 440 flywheel may not fit. I know of many places that have two-cylinder engine parts - very easy to find - but might be hard to pay for.
JD dozer mike
10-20-2006 09:29:00
some of them came with Detroit 2-53 diesels,I imagine the ICD 440 crawler engines are same also.
email
linkim@epix.net he has helped me with many used parts for my crawler. nice guy.
buickanddeere
10-20-2006 08:11:39
You have been talking to the wrong people. If the cam is flat then likely the engine has take on a load of water and or dirt. May as well pull it apart and repair all it now instead of later. A used cam & cam followers are a waste of time. The cam and followers require refacing before installation. Depending on the serial number the late 440's had a souped high HP engine that could cary a load. 1-800-522-7448 for the service and parts manuals you will require.
CPeter
10-20-2006 07:51:54
The gas motor is the same as a 440 Ag tractor and in fact almost all parts are the same as a 420/430. The interchange is good on these and many parts will fit and work even if they are not the same. I think you have a nice machine and you should feel good about having it. As far as a four cylinder replacement, the two cylinder is a better engine that the 1010 which you MIGHT be able to fit in there if you replaced almost everything from the transmission forward. I think any 420/430 cam will work. Others, like Lavoy might have a better idea. You could check with him.
