charging system on a 4010 diesel
4010 puller
10-22-2006 17:44:16
Hello Folks:
My tractor is not charging because the batteries always end up dead. I have the factory 24 volt system. How can I check the generator with the tractor running to see if it works? If this checks out good, what"s next the voltage regulator, and how can it be tested? This problem is getting old real quick because it always has to be jumped or coast started and it always stalls in the worst places.
Thanks!
4010 puller
10-24-2006 19:29:10
 Re: charging system on a 4010 diesel in reply to 4010 puller, 10-22-2006 17:44:16
OK guys, how do you polarize the generator? The tractor sat for quite awhile (a year or two). The starter has been rebuilt, a few wires replaced from switch to starter, and new batteries. What needs done to polarize the generator on the 24 volt system? Which terminal can I test on the generator to see if it is putting out the correct voltage?
Thanks
HTR
10-24-2006 20:31:54
 Re: charging system on a 4010 diesel in reply to 4010 puller, 10-24-2006 19:29:10
To polarize, with a jumper wire connected to the battery A terminal, on the regulator, that is the blue wire, make an arc to the battery A terminal on the generator.
To see if the generator is charging, measure the voltage between the A, blue wire circuit, and the B circuit, brown wire circuit, with engine off. Start engine, run about 1500 RPM, if voltage goes up the generator is charging. If you don't get voltage rise, full field the generator by connecting a jumper wire from the field terminal and A 2 terminal on the back of the generator. Measure voltage between A1 terminal, and field terminal with the jumper wire still connected. If voltage goes up the generator is capable of charging.
G/MAN
10-23-2006 13:45:52
What if any accessories (extra lights, etc.) do you have on the tractors, and how are the connected into the system? Your 4010 uses a "split" electrical system - a 24-volt starter and a 24-volt generator supplying current to charge 2 12-volt batteries that are connected in series to provide 24 volts for starting, but that each supply power for half of the remainder of the electrical system. If accessories are connected to only one battery, that battery will always be down and you won't be getting your full 24 volts for cranking. The common fix for any major problems with one of those electrical systems is to change it over to a straight 12-volt system. Deere makes a kit for doing this (indluding a 12-volt alternator and starter) and they're not cheap, but usually don't cost more than replacing a major 24-volt component like the starter. You need to get, read and understand an electrical schematic for that system before attempting diagnosis, as they're a different breed of cat.
Jim in AK
10-22-2006 21:47:48
Any time you disconnect anything in the charging system you need to reenergize the generator by momentarily shorting the regulator out. Even if all you do is disconnect the battery. Check your manual for that procedure.
Jim
Bob
10-22-2006 23:13:09
 Re: charging system on a 4010 diesel in reply to Jim in AK, 10-22-2006 21:47:48
JIM,
That's NOT true, although it won't HURT, if done properly.
At this point, he MAY need to polarize the generator, however, in general, it DOES NOT need to be done to a working system, just because the batteries were disconnected.
Do you know HOW to explain how to do it on the 24-Volt systems? I have not done it for a LONG time, and, as you know, you only get ONE chance with these 24-Volt systems, or ALL the SMOKE gets let out, IN A HURRY!
That's why I did not suggest it, as I would rather admit ignorance (forgetfullness?) than steer him wrong as to the correct procedure for this 24-Volt system!
Anyhow, restoring the residual magnetism in the soft iron polepieces and the "belly" of the generator is what "polarizing" is all about.
It needs to be done when a NEW generator is installed, the old generator has been apart for repairs, or has been off of the tractor, and banged around a bit, OR the machine has sat unused for a LLLOOOONNNNN GGGG time!
Simply disconnecting the batteries or some wiring for a while will have NO effect on the residual magnetism in the generator, so there's no need to "polarize" it, under those circumstances.
Glen in TX
10-23-2006 07:16:55
 Re: charging system on a 4010 diesel in reply to Bob, 10-22-2006 23:13:09
Bob, It was good and common practice to repolarize anytime something had been disconnected and I've seen JD & Delco mention it that way in service manuals that "any" time something was disconnected polarization could change or reverse and should be repolarized after connections are made and before starting with a generator system. It's not worth chancing it and frying new stuff again because you didn't. Not so on a alternator 24V system like on the military trucks or later loaders.
Gerald J.
10-22-2006 20:40:13
How long do you run it at each start? The stock generator only puts out 10 amps maximum. That can take 8 hours to charge a nearly dead battery, likely 4 yours to charge after a hard start. It won't catch up in ten minutes when limited to 10 amps and charging 70 amp hour batteries. Its designed to run many hours per start.
Gerald J.
Bob
10-22-2006 19:35:01
Start by checking charging system voltage while it's charging.
You should be seeing at least 28 Volts, if the charging system is working.
If it's not charging, I hesitate to suggest you mess with the regulator, as, with the high system voltage, it's real easy to let the smoke out! Don't wear rings or watches, etc., with metal bands, 'cause if you short them across the 24-Volt system, they'll burn you a hurry!
As the other poster said, a short in the starter can drain the batteries while it sits unused, as well as a short in the generator.
Either can be shorted by brush debris, moisture, and dirt, not to mention a bad field coil OR armature.
The key switch or light switch can drain the batteries over time, if full of damp dirt and debris.
Also, a battery cable with bad insulation, laying in the damp dirt and debris under the floorboards can drain the battery(s).
4010 Pulr
10-22-2006 18:54:32
I know it never stalls out on the Pullin track. Good luck with figuring out the chargin problem.
LJL
10-22-2006 18:38:38
check starter feild coils shorted and drawing the charge out of your batterys
