JD420W
John Carver
10-24-2006 18:02:03
I have a JD420W that is in need of a set of pistons. Before removing the pistons I removed the ridge in the bore with a ridge reamer, about 0.080 or more. Is there a Sleeve kit for this engine or does it need to be bored out?
rick in sc
10-25-2006 03:32:26
 Re: JD420W in reply to John Carver, 10-24-2006 18:02:03
John, Bore out. Pistons come in .045 .090 and .125 oversizes.
buickanddeere
10-25-2006 07:52:38
 Re: JD420W in reply to rick in sc, 10-25-2006 03:32:26
May as well perk her up a notch with some LP pistons. It will run fine on todays gasoline. As the 430 guy was told. May as well resurface the cam & lifters when she's apart. They may pass the eyeball test and still be worn out of time.
Hayfarmer
10-24-2006 19:03:59
Deere didn't make a sleeve kit for it. You might be able to find something through a machine shop. I'm not sure what oversize pistons are available for it.
Hayfarmer
10-24-2006 19:03:50
