overheating 60
jeffrey 1
10-31-2006 14:32:56
I have a few hours on a JD 60 that I bought put a new waterpump on it flushed the system but it seems to over heat without much work and I am up for suggestions
CHRISFROMSOLITUDE
10-31-2006 15:11:28
 Re: overheating 60 in reply to jeffrey 1, 10-31-2006 14:32:56
Make sure you check the temp with a temp gun or another source to make sure the gauge is working like it should before you tear into it again. Might save you some trouble.
F-I-T
10-31-2006 14:35:42
Could be as simple as a frozen shut thermostat. Do all the pipes/block/radiator top and bottom get to the same temp when it is overheating top?
Frank
