John Deere LA Fan Assembly
Jim R
11-08-2006 20:21:33
I am restoring my first 1941 John Deere "LA" tractor. The previous owner put an alternator and a different fan assembly on it. I want to put it back to original. I purchased a used fan assembly, and the pulleys line up perfect but the fan is only about an eighth of an inch from touching the radiator. Is there more than one fan assembly that fits that tractor, or is there something I don't know about? Thanks for any response!
DAH
11-09-2006 08:28:52
 Re: John Deere LA Fan Assembly in reply to Jim R, 11-08-2006 20:21:33
I, too, own a 1941 JD LA. It has the original generator and pulley setup. I have the same problem as you in that my fan blades are very very close to the radiator. I would guess perhaps an 1/8 inch to 3/16 of an inch. I guess this is just the way it was designed.
dab
11-09-2006 06:45:12
Lot's of different ones. Do you have a serial number? Off the top of my head I think there are about 10 different set up's between the -L-;-LA-'s;and -LUC-/-LUS-/-LUW- motors.
Mike M
11-09-2006 07:32:44
 Re: John Deere LA Fan Assembly in reply to dab, 11-09-2006 06:45:12
They may of even gave you one from an M,MT as they are similar ?
