Wiring Caused Fire
1951 B
11-11-2006 15:42:54
I started my "B" and drove it out of the garage today. Went back in to throw clothes into the dryer and when I came back, the "B" was on fire. I shut it off and found that the wires under the dash and all the way back to the battery had melted.
What caused this?
I always disconnect the battery when I am through using it and have never had a problem in the years that I have owned it.
What size wire should be used to rewire it?
Thank You.
TimS in Mo
11-11-2006 16:47:47
 Re: Wiring Caused Fire in reply to 1951 B, 11-11-2006 15:42:54
Sorry to hear about your fire on your tractor, I hope you don't have to much repair to do.
The cause could be a lot of things, obviously some sort of short circuit caused excessive heat to start the fire. The cause of the short could be a mouse chewing a wire, an old frayed wire finally shorted to the frame, etc.
I would use 12 gauge wire, that's the wiring on my 4010 is from the looks of it.
You might think of adding a fuse block in the wiring harness, a fuse would have stopped that wire melting and fire from happening in a lot of cases.
