2010 stuck in gear
John J. Otto
11-15-2006 11:37:25
I have been experiencing problems with my 2010 first the one brake has been locking up in reverse and now the tractor seems to be locked inbetween gears wont go either way it is a consol shift model it seems to have a lot of play in the shifter any ideas ? it may be a 2010 but it is still a JOHN DEERE
Art C
02-15-2008 16:30:26
 Re: 2010 stuck in gear in reply to John J. Otto, 11-15-2006 11:37:25
I have a 2010 that does the same thing, the shifting mechansim under the dash is most likely your problem, if it"s like mine it"s just worn out from years of use. There are bushings in the shift lever that wear out as well as a lock that makes the synchro work . First try and unhook your shift levers under the running board and then shake the lever around , it may unlock. If it dosen"t you have remove the steering wheel, then the throttle control , then the dash panel. That will expose the shifter and you can see where it"s jammed.
