JD Cast Front Wheel FH
40 JD G
11-15-2006 14:24:29
I have a Cast adjustable front wheel that i think fits a JD A and G. Whe casting number on the back is W273C, and was wondering if this is for sure a wheel for a JD.
ET
11-16-2006 05:04:19
 Re: JD Cast Front Wheel FH in reply to 40 JD G, 11-15-2006 14:24:29
I have a set of those ajustable F&H front wheel on the front of a F20 Farmall. IH has them listed in their parts book.
Duane Larson
11-16-2006 06:59:17
 Re: JD Cast Front Wheel FH in reply to ET, 11-16-2006 05:04:19
ET,
Could you tell me what the casting number on your F20 wheels are? Thanks!
ET
11-16-2006 09:44:13
 Re: JD Cast Front Wheel FH in reply to Duane Larson, 11-16-2006 06:59:17
The casting number for the wheel center is W273 and the F&H hubcap number is N846A. It looks just like a AO hub cap.
Duane Larson
11-16-2006 11:12:51
 Re: JD Cast Front Wheel FH in reply to ET, 11-16-2006 09:44:13
ET,
Thanks for the casting number info. I gather there is no letter after the W273 - sometimes they are cast in another segment of the wheel not adjacent to the 3. My notes show I saw a W273L on an F20 - perhaps F&H made two different castings, which would not be too unusual.
Duane Larson
11-15-2006 18:19:10
40 JD G,
Yes, your F&H W273C 3-way adjustable front wheels are for either an A or G. They are advertised in early Firestone tire advertising when Firestone was pushing the dual wheel concept hard (too hard for JD's liking).
The 3-way cast wheel was used on a number of tractors, and the "usual" way of telling them apart is by the last letter (C in your case).
