Frank, I was going to build a Baker fan a few years ago & measured quite a few working ones to get an idea of what I would need to design. Problem is I can't find my notes at this moment [might still be in my other truck]. If I remember correctly [& that will be scary as I have a full blown case of CRS] the vanes were in the ball park of 18” X 24” with some running a little larger for the higher horsepower. Some used ¼” steel & others used 3/16” steel & others used angle iron with plywood vanes. ~You could use a transmission but will have to support the input shaft as it only has an inner bearing, the other end is supported in the engine pilot bearing. ~I believe you might be better off using a jack shaft on your Baker fan to hook up your PTO, then belting that jack shaft to the main rotor shaft with a flat belt or V belts. That way it could also function as a flat belt Fan. ~For PTO loads I used a large water pump that I had a gate valve on & that could about stall most 2-cylinder tractors but a few years ago I belted up a 80 diesel & blew the pump apart. ~I was going to build another water pump set-up but think I will build a Baker fan instead. ~In the mean time I am just belting to another tractor [my 70 gas is the usual donor of friction] & that is how I am currently loading engines for tuning for power..
