reuse head gasket
36 A
11-18-2006 07:00:17
I did a valve job on my 36 A two years ago now it has a little knock so apart it comes.Can i reuse the head gasket or not.
jdemaris
11-18-2006 11:14:41
 Re: reuse head gasket in reply to 36 A, 11-18-2006 07:00:17
Just about anything you'll ever read or hear will tell you not to reuse a head gasket. That being said, I've done it many times with low-compression engines - and have never had a problem. That includes many old two-cylinder 6-1 compression Deeres, my Cletrac HG with Hercules, etc. I had the head off my Cletrac with Hercules IXB3 engine three times in past 30 years and have never replaced the gasket and never had a leak. If you are jerking around with a Deere - I don't think you're going to find a way to reuse the lead washers, though.
P Browning
11-18-2006 08:12:34
Can you? Sure! Should you? NO! You are counting on perfection in every sense when reusing the gasket; moisture content of the gasket, perfectly parallel surfaces, and a rather perfect torque job at the end. One of these will fail and you will be replacing the gasket before long. 'Sorry! (PatB)
