D spline shaft bearing
jfairchild
11-19-2006 16:35:43
During disassemble of 37 D that was stuck. We found that the culprit was the right hand bearing on the splined countershaft. It looked like it had never seen oil and had rusted over time. I don't understand how this bearing is to be lubricated. Is there suppose to be oil in the pulley gear cover (the bearing is unsealed to this side).There is no evidence that there was any oil in the pulley gear cover. Can someone enlighten me on how this particular bearing is lubricated during operation?
Glen in TX
11-20-2006 09:27:42
 Re: D spline shaft bearing in reply to jfairchild, 11-19-2006 16:35:43
If trans had enough oil in it should have been getting some oil from there to kept it oiled. If it got lots of water in it at one time or ran low on oil too long that's probably what ruined the bearing or being run on stationary belt pulley work never adding oil to reduction gear cover. There is suppose to be little baffle plate I think on later ones that helps keep that oiled too. Been to that spot before and sometimes it's just easier to pull the whole assembly out of a salvage tractor because sometimes those large gears can be a real pain to get off. Have had to leave them sit in press for days waiting for one to finally come loose and pop off. Parts from a 31 to 53 D will work on it. Holler at me if you can't find it as I may have a good shaft assembly already off.
