720 oil slinger
John Bouchard
11-28-2006 03:06:26
I took off the 1st reduction gear cover to repair a crack in the bottom and found the oil slinger gear loose in the bottom of the cover. It was off its pin in somr sludge so I know it didn't just fall out in disassembly. My question is , how common a problem is this? what prevents this from working its way back out ? The bushing is worn so I will rebuild that for a tighter fit on the gear.
