620 - Where do the holes lead to??
John VB
11-29-2006 05:32:53
I am rebuilding the carb on my 620. It bolts to the intake manifold with four bolts. The top two bolt holes on the manifold don't exit to the outside. They are full of rust and crud and the bolts don't want to go back in easily. The holes need cleaning out but I don't want to blow air in them if they exit inside the manifold. Where do these two holes exit? Thanks.
Mike M
11-29-2006 06:47:23
 Re: 620 - Where do the holes lead to?? in reply to John VB, 11-29-2006 05:32:53
I think they end up in the exhaust passage that is in there for when you run the manifold in the HOT setting.
John VB
11-29-2006 07:01:04
 Re: 620 - Where do the holes lead to?? in reply to Mike M, 11-29-2006 06:47:23
Thanks Mike.
