JD 60 Project
123farmer
12-04-2006 07:39:42
I am in the process of rebuilding a 1954 JD 60 but i need a new block for it. The block that i took out of it was cracked from top to bottom. Does anyone know where i can get a block that is ready to go with pistons and rings, and anyother engine parts if i need them. thanks
Anderson
12-05-2006 08:51:10
 Re: JD 60 Project in reply to 123farmer, 12-04-2006 07:39:42
Try Kim Johnson out of Minnesota. He has alot of used two-cylinder parts and probably has everything you need. His number is (218)729-7143.
