JD special tools
37 chief
12-04-2006 19:16:57
I have a repair manual for my JD 401b industrial tractor. It shows a special tool shaped like a Y for timing the cam, and other gears. It gives a number. Does JD sell special tools? If so is the tool number the same as the part number? Stan
jdemaris
12-05-2006 05:46:50
 Re: JD special tools in reply to 37 chief, 12-04-2006 19:16:57
As the other poster stated, it is nothing but a "glorified ruler." I worked in several Deere dealerships, and there were many tools such as this one - i.e. JD254. They hung on the wall and rarely got used. You can easily make one by welding a V to a piece of flatstock.
Jonathan in MA
12-05-2006 05:26:16
You really dont need that tool... its a glorified ruler. All timing marks point to the center of the crank with #1 at TDC. That "Y" part of the tool ensures that the straight edge is in the center of the crank... not rocket science-- save the money and use anything straight...
Mike M
12-04-2006 19:51:57
I don't see why they used that tool ? Most everything else has the gears marked. When I tore one down I just made my own marks on the gears BEFORE I tore it apart then just put it all back the same place. Those gears are real hard so you will need a small grinder like a dremal or an engraver.
37 chief
12-04-2006 22:17:02
 Re: JD special tools in reply to Mike M, 12-04-2006 19:51:57
When I tore it down I did mark the gears. I used a dremal tool, and marked with a white marking pencil. I just thought it would be good to double check. Stan
Mike M
12-05-2006 04:35:03
 Re: JD special tools in reply to 37 chief, 12-04-2006 22:17:02
a double check can't hurt. Maybe your local JD dealer has one you can borrow or make a tracing of it for a pattern ? That's how I got my clutch finger tool and oil seal installer for 4020's
430WLPG
12-04-2006 19:32:27
they used to, the tool number is the part number, bought one years ago.
