Turning Flywheel direction on JD 520
Joe in OKC
12-05-2006 11:45:10
Hi guys,
I've got a JD 520 that doesnt run - every few months, I turn the flywheel to keep the tractor loose. standin looking at the flywheel, I can turn it counterclockwise by hand and go round and round real esay. But I cant turn it clockwise exept for maybe 1/10th of revolution, then it gets stuck.
ALways thought a person could turn them both ways?
thanks for yer help, Joe
Mike M
12-06-2006 13:20:47
 Re: Turning Flywheel direction on JD 520 in reply to Joe in OKC, 12-05-2006 11:45:10
After farther review I'd say first check and make sure the starter drive isn't engaged causing this problem. Once you pull off the fyl. cover the rod and spring are not there to hold it up. Take a rubber strap and tie up the starter lever and try again.
P.S. and; Please don't get upset for Glenn and I wanting to take it off your hands.
Glen in TX
12-05-2006 13:34:09
Is it for sale with a good clutch pulley on it? :)
Mike M
12-05-2006 12:18:54
Somethings not right,better just donate it to me.
