B blocks
Jim Craig
12-14-2006 10:53:04
Will B1783R and B2500R blocks interchange for a 41 B?
jd b puller
12-17-2006 13:09:59
 Re: B blocks in reply to Jim Craig, 12-14-2006 10:53:04
Yes, and no... -They both bolt to the crankcase the same. -They both bolt to the head the same. BUT -The water manifold has a different mounting pattern - it supports the gas tank on the later ones. -The 41-46 block(B1783R) also has several extra tapped holes in it that attach the block to the frame rails.
What are you trying to do?
