JD 2240 remote single action cyl.
John Matley
10-12-2003 07:28:13
Where do I plumb a remote single action cylinder and its remote valve. Its plumbed for a double action from the factory and I want to leave that alone.
Thanks in advance, John
T. Sherman
10-12-2003 13:46:21
 Re: JD 2240 remote single action cyl. in reply to John Matley, 10-12-2003 07:28:13
I use mine as a single action by using one of the remote outlets. Just hook the cylinder to one of the outlets and if it doesn;t lift the equipment in the lift position of the control lever just hook into the other outlet. The oil will flow through the system and lower the cylinder when you place the control in the float position.
