2755 battery drain problem
joelmopar
12-27-2006 18:16:54
i have a 2755 mfwd that i just bought , it drains good charged batteries down rapidly , are there any common problem areas to start the search with , that would be causing this, thanks,
El Toro
12-28-2006 05:39:51
 Re: 2755 battery drain problem in reply to joelmopar, 12-27-2006 18:16:54
If that tractor has an alternator you may need a diode in the circuit to prevent battery drainage.
Hal
buickanddeere
12-27-2006 18:39:31
Disconnect the battery(s) and reconnect with an ammeter between the battery to starter or instrument connections. Pull one fuse at a time or disconnect items o breaker until the short is found. Finding this problem sooner than later is important. This is a situation that causes fires.
John Hurran
01-01-2007 11:29:36
 Re: 2755 battery drain problem in reply to buickanddeere, 12-27-2006 18:39:31
Use a test light instead of ampmeter--is alot easy to see.
joelmopar
12-28-2006 17:28:54
thanks for the advice ,
