440 crawler oil pressure
Joe Daugherty
12-30-2006 19:33:25
I just rebuilt a 44oic engine bored block turned crank new pistons and all new bearings.Runs great but can't get any oil pressure.Getting oil in filter canister but it is slow and no pressure.Had oil pump milled for tollerance but did not help problem.Getting no oil at all to rockers at top of engine, Suggestions?? Thanks Joe
Lavoy
12-31-2006 18:20:06
 Re: 440 crawler oil pressure in reply to Joe Daugherty, 12-30-2006 19:33:25
Just a wild guess, but had it happen on an MC recently. Check and see if the pin that holds the drive gear is not sheared. Pull the dist and turn the engine over while looking at the gear with a flashlight. We did that and discovered the pin was sheared. Put in a different pump, and had pressure almost immediately.
Lavoy
MolineManG1
12-31-2006 11:03:11
Could the pump be sucking air? Pickup tube cracked maybe?
Henry M
12-31-2006 05:31:16
Joe
Surely it won't be this simple but I have seen standard bearing inserts put in after turning a crank.
Not getting oil to the to could be a whole new issue with the installation of the rear cam bearing.. Is the slot in the bearing toward the bottom?
Joe Daugherty
12-31-2006 07:20:05
 Re: 440 crawler oil pressure in reply to Henry M, 12-31-2006 05:31:16
I know the slot in the rear cam bearing is down.I was concerened about it sliding away from the oil hole in the the block when i drove in the welch plug.So i was real carefull.Still don't understand the oil canister not having pressure,the oil pump feeds directly into it.If i had a restriction somewhere in the engine wouldn't this cause more oil to go to the canister? Joe
