4010 Pre Cleaner
4010 Pride
01-05-2007 11:41:15
Why do I sometimes see pictures of 4010 diesels without a pre cleaner or pre-cleaner piping above the hood? If there is no precleaner above the hood then what is screening the intake hole to the oil bath under the hood? Thanks men. Jon
msb
01-05-2007 14:02:57
 Re: 4010 Pre Cleaner in reply to 4010 Pride, 01-05-2007 11:41:15
Nothing. The intake sticks straight up under the hood.Precleaners were always an option with Deere since they were first used.The radiator screens are all that is really needed.
If You look, you will not see any precleaner bowls on Cat equipment. Cat engineers discovered that precleaners ground up the dirt they caught from the vibration of the tractor engines and it was fine enough to go through a paper air filter, so they did a field conversion on all Cat equipment sometime in the 60s. As a result Deere also did away with their(fruitbowl) precleaners in 1969 as did most other companies.
4010 Pride
01-05-2007 21:01:28
 Re: 4010 Pre Cleaner in reply to msb, 01-05-2007 14:02:57
MSB, wish I had your knowledge up here in NY...you"re great, thanks soo much!
61-4010
01-06-2007 20:00:40
 Re: 4010 Pre Cleaner in reply to 4010 Pride, 01-05-2007 21:01:28
Howdy. Since the 4010s had oil air filters, I highly suggest using a pre-cleaner. Without the pre-cleaner, the oil bowl gets dirty a whole lot faster. I'd agree with the reply regarding paper filters but with oil bath filters, I suspect they would trap the same sized particles regardless of with or without pre-cleaners.
4010 Pride
01-07-2007 18:32:27
 Re: 4010 Pre Cleaner in reply to 61-4010, 01-06-2007 20:00:40
"61-4010, thanks for the info. I greatly appreciate it. Jon
