US G vs. GM belt pulley
36 A
01-07-2007 20:18:55
what numbers are on the two pulleys. I think i have a US G pulley on my GM.What was the problem on the US G pulley.
DSK
01-08-2007 05:52:29
 Re: US G vs. GM belt pulley in reply to 36 A, 01-07-2007 20:18:55
As the cams became worn in the US pulley, the clutch would not stay engaged without holding the lever in. The US clutch never engaged with a snap as did the other tractors. The 2 pulleys are interchangeable, you need to change the pulley seal also.(sheet metal ring under pulley).
