This 4010D
Jim in AK
01-08-2007 09:34:05
is giving me fits!! Been trying to fix an inoperative fuel gauge for over 6 months now. New sending unit, two used dash units and now a new dash unit. Put a grounding wire on the sending unit and replaced the wire from sender to gauge. Got 13 volts at the gauge. Still dose not work!!!
Can any of you tell me what the heII am I missing? Seems that what should be a easy fix turned in to a real pain in my hairy behind. Just can"t figure out what is wrong.
Jim
Tx Jim
01-09-2007 04:30:31
 Re: This 4010D in reply to Jim in AK, 01-08-2007 09:34:05
Does your tractor have battery cable that connects to both batteries under floorboard? If so do you have a ground wire from LH rear batt. post to frame? Tx Jim
HTR
01-08-2007 19:05:35
A couple questions to help diagnose. Does your oil pressure indicator light work? Do all four head lights work? Does turning the lights on effect the fuel gauge reading?
Gerald J.
01-08-2007 14:09:37
Is the gauge case grounded?
Its not that complicated a circuit. 12 volts comes from the ignition switch to the 12 volt input terminal on the gauge. A wire goes to the sender and the sender flange plus the gauge case are grounded to the other side of the 12 volt circuit.
Even with the wrong polarity it will still work. It might read off, but you can adjust that by bending the float arm on the sender. You can run it on the bench without the tractor if you have a source of 12 volts DC.
In one post you say you find 12.9 VAC? There's no handy source of AC on the tractor other than inside the generator or alternator. But many AC meters will indicate a voltage with DC applied.
I switched my gas 4020 from positive ground to negative ground when I installed the alternator. The gas gauge still indicates, once I fixed the sender.
With the sender out of the tank and with a wire from its flange to ground, moving the float arm MUST change the gauge reading as well as the voltage across the sender. If those don't change when you move the float arm, the sender is bad. If grounding the wire that goes from gauge to sender doesn't move the gauge, the gauge or wire is bad. That wire from the gauge to the sender is highly suspect. Try a new hunk of wire there. Be sure of the gauge and the sender grounds and of the sender function.
Gerald J.
Bob
01-08-2007 13:01:11
The gauge IS polarity-sensistive.
IIRC, it operates on the (+) grounded 12-Volt half of the split 2-Volt system.
So, you should be seeing (-) 12 to 14 Volts, with respect to the chassis, as power to the gauge.
Once you have determined you have (-) voltage to the gauge, and the gauge is properly grounded, take then wire off the sender. The gauge should go to one extreme ("E" or "F"). Then, ground the wire to the chassis at the sender. The gauge should swing to the other extreme.
Often, over the years, the polarity of the connections got swapped at the LH and RH batteries, and the generator got polarized accordingly.
Here's a link to "gwece's" diagrams:
Jim in AK
01-08-2007 13:52:30
 Re: This 4010D in reply to Bob, 01-08-2007 13:01:11
Bob,
I did a "where it goes search" for # RE53664. It did NOT come up with a 4010 Diesel gauge. It came up as a L.P. gauge. See Deere's catalog 1116 Grid 2B10 Section 40 Page 3. I still think that the Deere dealer sold me the wrong gauge.
Jim
Bob
01-08-2007 14:44:11
 Re: This 4010D in reply to Jim in AK, 01-08-2007 13:52:30
JDPARTS shows the 4010 diesel fuel sender as # AR26434, and the fuel gauge as AR46271.
AR46271 comes up unpriced. (And unavailable, it turns out.)
I called my favorite DEERE partsman, and he checked and determined RE54427 OR RE53644 ARE acceptable substitutes for AR26271.
Have you determined the polarity of the "feed" voltage to the gauge, with respect to the chassis?
Have you tried disconnecting, and alternately grounding the sender wire, and observing what the gauge does, as I mentioned before?
TimS in Mo
01-08-2007 11:50:32
Is this a 24 v system, from the 13 v on the gauge it sounds like a 12v?
There are different gauges and sending units for 12v vs 24v from what I understand. Could you have a mismatched set?
Jim in AK
01-08-2007 12:31:40
 Re: This 4010D in reply to TimS in Mo, 01-08-2007 11:50:32
I just got back from the deere shop and they checked and said that I did have the right gauge and sending units. The book said that there should be about 12 VDC @ the battery side of the gauge. There is 12.9 VAC there. I still can't figure it out.
Jim
